AMK DaBenz PC Case Review
Supplied by AMK Computer
Take DaBenz out for a test drive.
A PC case with headlights and a grill? It’s true and AMK
Computers
let us take DaBenz
out for a test drive. It has been our experience that many PC cases are the
same chassis except for the bezel but AMK chooses their product line carefully.
It’s not until the “up close and personal” do the reasons why become
obvious.
wscase
Specifications
  • 19″ deep x 16.5″ high x 7″ wide.
  • 4 external 5.25″ drive bays.
  • 2 external 3.5″ drive bays.
  • 4 internal 3.5″ drive bays.
  • comes with 300 watt PSU.
  • Aluminum chassis w/plastic bezel
“DaBenz” is aptly named for the front bezel.
bottombezel
The hook to this case are the “headlights” and “grill”.
The “headlights have a blue LED in the larger lamp assembly which come
on with main power and the red LED lamps light with hard drive activity. Left
and right are tied to the same circuit. The following image shows both LED sets
in operation and the picture does not do the effect justice.
cuheadlights
lit
Behind the push-lock grill are two USB ports, a mic jack and headphone jack.
The faux chrome plastic door cover would have been better if made of actual
metal but this would have added to the cost. Directly above the door is the
reset switch which is a bit awkward to activate. This could be a plus or a minus
depending on how it is looked at. As a minus it is a bit hard to depress but
as a plus it prevents accidental resetting of the system.
usbdoor
The front covers to the 4 external drive bays are a dark charcoal grey and
not pure black. The color difference between a black faced drive and the cover
is almost negligible. A person would have to specifically look for the color
difference to notice it….providing (eek!) beige components weren’t installed.
AMK added a custom
side intake fan to the review sample and the door panel could easily accommodate
two vertically stacked 82 mm. or 92. mm fans. The metal panel is of a “medium”
weight thus strong enough for structural integrity but won’t need an industrial
diamond cutter to cut through. It would be our advice to order the case with
custom fan modifications right from AMK and let them worry about the cutting
and mounting. That guarantees a perfect job every time.
wsside
The pattern in the side are punches in the case side panel which give the illusion
of cooling vents. True modders may have preferred a clean side panel allowing
freedom to cut their own design without worry of incorporating or cutting around
an existing pattern.
The interior is deceivingly normal but there is more than meets the eye.
wssideoff
The PSU tucks in at the top and is supported on one side by a metal flange.
psufanarea
Notice the exhaust grill and mounting holes below the PSU hole. This is a dual
purpose mount that can accommodate 82mm. and 92mm. fans. Squeezing in a 92mm.
fan for a rear exhaust is a definite bonus. 92mm. fans can push a lot more air
or they can push the same as an 82mm. fan but at lower RPM and thus quieter
noise levels. The days of 60 dB Deltas should remain in the past.
This double fan mount is the first of the “up close and personal”
reasons why AMK carries DaBenz. The only thing that would make this better would
be to completely cut away the many small circles grill and install a fan with
a chrome finger guard which has less restrictive airflow.
pcislots
7 standard PCI slots with breakaway covers. The parts bag only has two spare
PCI slot covers so pick carefully which ones to breakaway.
There is space for 4 internal 3.5″ drives BUT a quick count reveals 7
slots. The top two are for the external 3.5″ drives such as a floppy and
ZIP. Below is space for FIVE 3.5″ drives not four.
mainbays
The front intake fan area can accommodate for an 82mm. or 92mm. fan but the
front bezel has to be removed to turn the screws into the fan body.
intakefan
It is important to remember that a fan has to go in before drives are installed.
Four external drive bays are standard these days.
externalbays
There is another “up close and personal” design plus with DaBenz.
All the edges are rolled and any corner is surprisingly dull. Though not impossible
it would be rare to scratch or cut skin while working inside the PC case.
The bezel removes by way of 6 clips (3 per side). This makes removing the bezel
easy but could be a pain if accidentally broken.
cubezelhooks
Behind the bezel is the wiring and access to screws for the front intake fan.
DaBenz comes with the front USB leads which are separate wires as opposed to
a plug. Separate wires are better in the long run as each USB connection layout
on a motherboard may be subtly different. It may just take a few minutes more
to figure out the wiring connection. RTFM.
insidebezel
The external bay covers are held in place by screws and not breakaway design
like many other inexpensive cases. This is another plus to those who may pull
a drive and want to put a cover back.
externalbaydoorsscrews
Back to the wide shot of the case and a look at the backside of the non-removable
motherboard tray.
wsothersideoff
The 5.25″ drive bay area only has one set of screw access points which
isn’t a problem…just noted. Read our Tech
Tips: Cable & Wire Organization
guide and learn how to hide cables but
be warned the space is very narrow in these smaller cases. Some wiring may be
able to be hidden behind the motherboard tray but not a lot.
The rear of the PC case features a backplate cover held in place by a screw.
It can be easily removed to allow for a custom backplate that comes with every
motherboard. If DaBenz’s backplate will work then use it as it is much more
solid than those flimsy, paper-thin aluminum backplates that come with motherboard
packages.
wsrear
curear
Air for the front intake fan comes up through the bottom of the bezel. A modder
could easily install some filter foam to cut down on dust. (hmmmm….maybe a
new Tech Tip idea?)
bottomintake
Hard rubber feet will prevent scratches where the PC may reside. A disappointment
for some may be the lack of PC speaker in the case but a lot of motherboards
come with their own POST BEEP noise makers. PC speakers for this purpose may
become a thing of the past.
Installation
The parts bag came with the assortment of screws and a combination of plastic
standoffs and brass screw posts. The one problem was there weren’t 9 of each.
There were 7 of the brass screw posts and even less of the plastic standoffs.
7 is sufficient to secure a motherboard but it seems odd that at least 9 of
each were not included. A combination will have to suffice.
Installation is straightforward and there were no problems.
wsinstall
Those not familiar with the small confines of a 16.5″ case will quickly
wonder where to put those endless miles of cables. Most do what we did and just
stuff them into an empty external drive bay(s).
cablemess
Bad PC enthusiast….BAD! We should no better and we are ashamed but a quick
read of the Tech
guide will give handy suggestions on
how to hide and arrange that mess.
The 82mm./92mm. rear exhaust fan area can easily accommodate either sized fan.
rearexhaust
wscase
If a certain car appeals then the AMK “DaBenz
is certainly a trendy choice. Consumers ultimately buy products like this based
on aesthetic appeal. Overall it is well put together PC case and for under $35
USD ($60 CAD) including power supply it is a very good price.
lit
Ratings breakdown.
There are several ratings categories that are used and all may not be applicable
to every product. Our scoring system may not also be “in-tune” with
what you see on other sites. We made it harder to win awards as every product
cannot win the race even if it places well. Just because a product on our site
hasn’t an award does not mean that it is a poor product. Products should fulfill
your needs, have acceptable longevity, and as a pleasant side effect…exceed
your expectations. What you need it for and how it fits those needs changes
with each individual.
Our thanks to AMK
Computers
for their continued support of this site.
Highs
  • Stylish appeal to some.
  • Attractive price.
  • Good cooling.
Lows
  • No included PSU.
Scores Breakdown
Attribute Score Comments
Bonus items & software 7.5 The parts bag could have contained more motherboard standoffs and at least 2 more PCI slot covers.
Design & layout 8.5 Very good for the price but a removable motherboard and drive bay would be the icing on the cake.
Features & options 8 82/92mm. intake and exhaust mounts, rolled edges, no sharp corners, lots of internal drive bays.
Modding possibilities 8 Top blowhole and side intakes can be easily accommodated and should be. The punched vents may be a design hindrance. Front bezel is plastic so no modding there unless you are brave with a dremel.
Overclocking features 9 Space for stock cooling with 82 or 92mm. intake and exhaust fans but AMK can add a top blowhole and side panel fans to turn this little guy into a cooling demon.
Performance & stability 10 The test system did not fall over on its own. (lol)
Presentation 8.5 I just know that someone is going to mount a Benz hood ornament somewhere on this case.
Price / value 8.5 Under $35 USD for a case and PSU? Good stuff for this type of PC case!
Total score 68/80 85%
  1. profdlp
    profdlp Cool. I know people who will want one of these just for the "wow" reaction from their friends the first time they show it off.
    Nicely written review, I enjoyed it.
    Now, this would take a larger heat sink, but it's my kind of grill:
  2. MediaMan
    MediaMan lol at grill. Heat up dem briquettes would ya?
  3. Geeky1
    Geeky1 The front end looks an awful lot like the front end on the Mercedes CLKs... wonder where they got the name? ;)
    Have to get myself one of these things, if just to go with the avatar & sig... :D
  4. MediaMan
    MediaMan As I said in my review....wonder how long it will take for someone to mount a hood ornament from said car on it?
    ;D
  5. Geeky1
    Geeky1 Well... I do have a few I could slap on there... hmm... ;)
  6. keto
    keto Well done, MM ... tho I think ... make that I "no" there's a typo near the bottom of P.2 :p
  7. Thrax
    Thrax Good review, as per the usual expected quality from our fearless leader...But damn the case is ugly.
  8. Spinner
    Spinner I'm looking for cases at the moment, unfortunately, that one didn't really take my fancy. Nevertheless, I nicely written review MM'.
  9. Nixxer
    Nixxer
    Get a Xaser III. If you like the look of them they are ace.
  10. Spinner
    Spinner
    Could I have a linky winky pleasey weasy?
    (I've been drinking, and yes, I know it's early over here):crazy:
  11. Nixxer
    Nixxer Here you go, the Xaser III review.
    Clicky.
  12. Spinner
    Spinner Thanks. Doh! Didn't realise there was one on the main page.
    /me slaps himself
  13. CyrixInstead
  14. Necropolis
    Necropolis
    CyrixInstead said
    Ace....? :wtf:
    They are horrible (IMO)
    http://www.thermaltake.com/products/xaser3/v1000cblue.htm
    I like the look of the Xasers.
  15. Thrax
    Thrax I should note that Xaser cases are uglier than this AMK case.
    A horrible butchering of a wonderous thing.
  16. CyrixInstead
    CyrixInstead I like something a little more stylish.
    I recently bought the Coolermaster ATC 710 in black, to go with my Black TFT screen.
    http://www.coolermaster.com/case/products/atc710.html
  17. Necropolis
    Necropolis I guess its all down to personal choice at the end of the day :D
  18. Spinner
    Spinner To be honest I'm not quite sure what I think about the Xaser's, but I wouldn't count them out. I've also been looking in the direction of Coolermaster, in my case it was the Wave Master TAC-T01 that caught my eye.
  19. profdlp
    profdlp
    * Spinner slaps himself
    Ya already said ya was drinkin' - how much did that hurt? ;D
  20. Thrax
  21. Spinner
    Spinner
    Original Message Edited Out by Spinner
    p.s (Love you...);)
    p.s.s (Your right Thrax, that is a nice case also)
  22. MediaMan
    MediaMan If you can hold off on buying a case for a while....I'm digging around for "the perfect case". Whether I'll find it or not is unknown but I'm meeting with a retailer and supplier for 6 retailers this week to pass on our feedback and see what goodies they have.
    The perfect case feedback. (maybe)
    • Average price range $80-125 USD
    • Removable motherboard tray (slide out back or slide out side)
    • Drive rails (min 4 external bays….5-6 are better)
    • Name brand power supplies (ANTEC, ENERMAX, PC POWER &
    • COOLING) They don’t want to buy cases with “generic” PSU of 350 watts that they have to replace with 400 watt name brand PSU’s. Either sell the case w/o PSU or put a decent 400watt PSU into it.
    • Space for 2 intake fans for active cooling across HDD
    • Removable hard drive bay (4 drive space) Drives to be in line with case not at 90 degree angle.
    • Front USB 1.0-2.0/FIREWIRE ports hidden. Prefer mid to top level position instead of on bottom edge.
    • Rolled edges and no sharp corners
    • Screwless design
    • 2 exhaust fans
    • Fans should accommodate 80 and 92 mm. fans (clip mounts not important)
    • Exhaust grills should be as non-restrictive as possible.
    • Solid construction. (weight isn’t as important anymore)
    Bonus Add-ons
    • Removable Floppy bay
    • Space for two power supplies
    • Fasteners & zip ties. Ring style and zip tie mounts for cable management
    • Included drive faceplates to disguise beige drives therefore keeping bezel aesthetics
    • External drive bay hinged door. (no lock necessary)
    • 3 position fan switch for low-medium-high accessible in same area as USB-1394 port and hidden but not behind bezel like Lian Li.
    • Optional windows for side panel.
    • Aluminum or metal didn’t matter. They want sturdy.
    • Overwhelming favor towards 19”-24” towers for space.
    • Some asked for more width (especially those who watercool)
    • Only one floppy external is needed but include a 3.5 mount for the 5.25” bay for those who may have a zip drive. (Rare)
    • Some asked for power supply cables to be shrunk wrap with sleeving that matches case color. (loom?)
    • Some are leaning towards 92mm. fans that blow more air at lower noise levels.
    • Most asked for ducts and channels to hide wires in. A wider channel running down the drive bay vertical line at the non-door side of the bays would be great to hide wires in. Same as horizontal.
    • People want to be able to have a tornado if they want but make it quiet too. (50 CFM fans) Some said they are tired of buying cases with fans they have to replace because they are too weak.
  23. Geeky1
    Geeky1 MM... you forgot one thing:
    BIGGER FANS
    Support for BIG fans is really, really important- not dinky little 120mm things; 172mm/6.75" Comair Rotron units. They're <$20 each, so they're not prohibitively expensive, and they do 235cfm+ apiece, and at 1/2 their rated voltage they're nearly silent while still moving a lot of air.
    Also, not only are fan clips unimportant, they cause more problems than any other part of my case. I can't mount 38mm deep fans because the fan clips can't handle them. Screw mounts are just fine. I thought when you were asking for the size, you meant the depth. Depth should be 18"+, and height should be a minimum of 20", up to 27"
    Take a look at an Apple G3 case; the wire management is incredible...
    And that 2 intake/2 exhaust fans isn't sufficient. If they're 80/92mm fan mounts, 4 intake, 4 exhaust is good. 120mm fans should be 2 intake, 2 exhaust, as should the rotron fans...
  24. mmonnin
    mmonnin I would like to have enough room to put front case fans in and still not have my HDDs hang over my motherboard. Sometimes all that is needed is an extra inch or 2 from front to back.
    I know with some cases if you put an intake fan in you have to move the HDD a position towards the back of the cases several inches just because there are not enough holes in the HDD mount. Then it hangs over the motherboard and is harder to work the cables.
  25. Spinner
    Spinner
    Yes cool, I'll certainly wait as long as I can. However, is it really possible to find or know what a perfect case would be like. As I imagine each persons needs and requirements differ from individual to individual. Perhaps a better title would be, "the best all round case"? Just a thought. I still like those Coolermasters though.;)
  26. MediaMan
    MediaMan That is true Spinner. "The best all around case".
    Aesthetics are a personal thing. I'm just using opportunities to pass on all the things I've gleamed from the members to tell manufacturers. :)
    I'll see what I can dig up for you.
  27. Spinner
  28. GHoosdum
    GHoosdum Geeky... looks like a mod is in your future, if you wanna put some Rotrons in!
  29. danball1976
  30. MediaMan
    MediaMan I have gone out into the world and met with three different sources. I arrive back on the mighty Short-Media shores before you.
    And what bounty did I bring back?
    Coconuts....because they are better than what I saw. The only new case I saw was a Chenbro PC61166 (use the pull down menu) and the UMPTEENTH variation of this case. Yes the UNEEC is the original and ANTEC, THERMALTAKE, etc. etc. etc. don't build their versions. UNEEC just customizes them because those companies order enough of them. Any case manufacturing company will let you advertise the product as if it were your own if you buy a couple of shipping containers of them.
    The new variation of the most popular case of 2002-2004 will have a 500 Watt PSU with clear molding, front temperature gauge, neon lighting and its own assortment of colors. Basically....it's the same case with a couple of new features. Should retail for $195 USD. It has value as buying everything separate would be much more.
    Is there anything new out there?
    Not really. Sadly disappointing. The ANTEC/THERMALTAKE/UNEEC has been done to death and it is reaching the point where you buy the case and that's it....no fun modding.
    I shall keep looking but I looked at over 70 PC cases from Chenbro, Supermicro, and a few other companies that are manufacturing for ANTEC...Thermaltake...etc.
  31. WuGgaRoO
    WuGgaRoO im supporting spinners...i believe his case is the nicest...by far
  32. Spinner
    Spinner I see, well thanks very much for your dedication, but I feared as much. One of these companies needs to step out and take the initiative, and design something really off the wall. Perhaps something inbetween the likes of the cube PC and todays midi-towers. A case which can accept standard ATX motherboards, but also be innovatively compact in its design. I really have never seen a case that has set my eyes on fire. I also look for a case to be acoustically sound (if you pardon the pun). A case that keeps it self quiet without turning itself into an oven.
    My current case, the Globalwin 802 classic, is probably one of the most functional main stream (i.e doesn't cost more than $70) cases I have ever had the pleasure of using. But as we all know, beige boxes aren't exactly fashionable anymore. It's a tricky topic PC cases, because some people put style over functionality and design, where as some just want to spend as little money as possible. I myself also prefer cases which don't come with their own PSU, as I like to choose my own.
    To comment specificaly on your findings, I actually found the below case quite refreshingly bubbly. However, I think it would suit my sisters pad rather than my own.
    That popular UNEEC design however, I find curious, but not really my cup of tea, saying that though I believe Thermaltakes take on it (sorry again) to be very well thought out, however I feel it isn't cosmetically very attractive. But like I said that is my opinion, everyone has their own tastes, which is what makes choosing a case so tricky, because there are more factors at stake than just functionality, at least there is for me.
    Thanks again for sharing your findings MM', do you think it would be possible to fashion a case out of Coconuts?
    p.s (...and was that whole bounty and coconuts thing supposed to be a joke? you know the chocolate bar?)
