Anandtech has discovered that LGA1156 sockets manufactured by Foxconn and used by a host of mobo vendors are roasting chips during extreme overclocking due to poor contact with the Lynnfield CPU.
The trouble, says Anand, lies in the VCS/VSS pins, or the region of the socket responsible for delivering power to the CPU. The site estimates that up to 155W can be in the pipe to those pins under full load, but poor CPU/socket contact reduces the number of usable pins; the remaining pins struggle to handle the load and eventually burn up, taking any connected CPU with them. Anand points to two pictures in particular which demonstrate the difference between a socket with proper connection, and one without.
The pads circled in red have no impressions or scuffs to indicate that socket contact was ever made. Note also the burned pin in black. (Image credit: Anandtech.com)
This socket from a different manufacturer has impressed/scuffed all available pads on the same CPU. (Image credit: Anandtech.com)
For a list of the affected manufacturers, more pictures and alternative sockets to look for, skip on over to Anandtech for complete details.
