Building high end gaming pc, have I made a good choice in parts?
Hi there, my friend has a pretty old pc and wants to build a new one. He is getting into gaming, crysis, cnc3 and lots of the latest games. I said to him, why not build a pc. That started the ball rolling and now he has saved up alot of money to build this pc. He has bought a thermaltake armour + and i helped him fit his old pc into the new case. Proberly the worst pc ever to be inside an armour + but i gave him an idea of how to build computers, he is now hooked on UV lights, water cooling and all the latest hardware. I gave him the computer bug
He will be buying all the stuff in a months time.
We already have the case, and there is no issues about cooling or space.
Also, he has a dvd drive.
The planned specs are:
Intel Q6600 2.4ghz, will most likely overclock to 3.0ghz maybe further if we have a good chip. COOLING: arctic cooling freezer 7 pro
Asus Maximus Formula II P45 Chipset motherboard
2GB Corsair DDR2 1066mhz XMS2 dominator ram
ATI 4870 X2 2gb graphics card.
Thermaltake toughpower 1200W PSU cable management, (overkill i know but he wants it) I thought the corsair 1000w PSU would of been overkill, but a better choice.
2 250GB 32MB cache hdd's running in raid0 and a 500GB for storage
How does it all sound?
.He will be buying all the stuff in a months time.
2) The Formula is an uninspiring motherboard with little more prowess for the dollar than any other enthusiast motherboard. The P45 is also an uninspiring chipset that offers little for the price premium. You're better off looking at the LANPARTY DK X38-T2R. Better overclocker for a lot less money.
3) Again, another weird choice in the context of this computer. The system should really have 4GB of memory. Any popular/quality brand will do: OCZ, Corsair, Mushkin, G.SKILL, etc.
4) Good choice on graphics.
5) A complete and utter waste of money. Utterly. Go with a quality 600-700w PSU, such as anything from OCZ or Corsair and it will be more than capable of powering this system.
6) If you want storage, get storage. If you want speed, prepare to lose everything. RAID0 is a recipe for lost data. If you don't want it to go tits up, you're going to need another 500GB hard drive on hand just for backing up all that important data to.
I will have a look for some yorkfield cpus.
Glad you agree with the 4870 X2
yes, we will go to a 4gb kit, also, a lower wattage psu proberly a corsair 750w or similar.
Ok, no raid arrays, just a 500gb hdd. and a 120gb storage
I have to say, the mobo is very very good looking, also, if he is saving money from the psu and hdd's then he is willing to pay for the mobo even if it isnt much better than other mobos for much cheaper.
is this yorkfield? http://www.ebuyer.com/product/141517
It overclocks well doesnt it. surly it would be fast enough.
The Q6600 would run fine, but I just think it's a bit silly to waste money on overkill power supplies and motherboards when a significantly superior CPU costs about 60 quid more, and a whole lot less than you're saving.
Thanks
I don't get it. Why would you make your storage drive the inferior-sized drive? Put the OS on a 120gb drive, put all files and media on the 500gb, and when the OS needs a refresh or something gets borked, you can just reinstall and keep your data. Why in the world would you need 500gb for an OS drive?
Also, does the Armor have a window? Who really cares what the mobo looks like? I'll plug the Gigabyte GA-X38-DQ6, but I don't know what your price ranges are. It's a very quality board, though.
Thrax's motherboard, storage, RAM, and PSU comments - spot on!
Not to worry. Even bottom of the barrel Q6600s will do 3.0 without a voltage boost. If your friend changes his mind and wishes to overclock more (cakewalk with the Q6600), he may not be happy with the Freezer 7 Pro. It's a decent cooler, but is far outclassed by many other relatively inexpensive heatsinks. Examples of excellent Socket 775 coolers for good prices are the OCZ Vendetta 2, Sunbeamtech Core Contact Freezer, and the Xigmatech (high end model - I forgot the name).
No need for that expensive Dominator DRAM. He'll get much more performance for the same money by purchasing 4GB of a less prestigious model.
mobo http://www.specialtech.co.uk/spshop/customer/product.php?productid=6259&cat=0&page 153
psu http://www.specialtech.co.uk/spshop/customer/product.php?productid=5664&cat=735&page=1 147
RAM http://www.specialtech.co.uk/spshop/customer/product.php?productid=3309&cat=506&page=1 41
graphics card http://www.ebuyer.com/product/148278 355
HDD http://www.ebuyer.com/product/130826 47
CPU http://www.ebuyer.com/product/131950 114
Snarkasm reply about the Gigabyte GA-X38-DQ6, it is the same price as the Formula so within my price range, i would be happy to make the change if that mobo is higher quality http://www.specialtech.co.uk/spshop/customer/product.php?productid=4503&cat=0&page
Did you consider getting the smaller drive for the OS and a larger drive for storage? I only see one HDD on the list.
DDR3.. then by all means X38/48.
corsair do a 750w it is 81 pounds, 6 pound p&p here and it is not modular
http://www.shop.bt.com/productview.aspx?Quicklinx=4RYB&CategorySelectedId=11259&PageMode=1&NavigationKey=11259,50113
OCZ do a 900w modular for 82 pounds, 8 p&p here
https://www.aria.co.uk/Products/Components/Power+Supplies/500w+%2B/OCZ+900W+ModXStream+Modular+PSU+?productId=29109
So a 3 pound differences for 150w more and no mass of cables. Are these OCZ ModXStream psu good, they have a 3 year warranty
OCZ ModXStream 900w- 82 pounds
OCZ 4gb DDR2 PC2-8000 ReaperX- 78 pounds
Seagate ST3500320AS 500GB Hard Drive SATA II 7200rpm 32MB Cache 46 pounds
Asus Maximus II Formula (P45) Motherboard- 153
Q6600- 114 pounds
Sapphire HD 4870X2- 355 pounds
total- 828
29 pounds less and 2gb more RAM that befor
You will have a very fast system with plenty of power to spare.
I'm running a ModXStream 780. It's very good. Excellent PSU. Check out JohnnyGuru and Anandtech for thorough, methodical PSU reviews.
To me, modular PSUs are worth the premium price.
this will be my 1st build but revorocks will be there if there is any problems.
thanks for the help i will buying the parts in around 3 to 4 weeks
pentium 4
ati 9250 (that is so powerful it can play css on low at 35fps) lol
i ran 3dmark06 it got 673
i hate this pc it do's not even turn off. i have to click turn off then wait for the hdd to click then flip the switch on the back of the psu.
I Just can't wait to see the back of it.
http://www.ebuyer.com/product/135192
they are very cheap for the power they give.
is that is no good the 4870x2 needs a 6pin and an 8pin
Im not that sure but doesn't the 4870 X2 come with a 2 molex to 8 pin PCI-e power connector?
Therefor you wouldnt need that 8pinm but you would have 2 molex's dangling around, i imagine i could sleeve or ziptie them together though.
