Opteron 170 + Asus A8R-MVP - My first timer overclocking journal
Since this will be my first time attempting anything more than a rudimentary overclock, I am going to journal my experiences here. Perhaps this can help other OC newbies like myself.
The first step was obviously deciding what hardware to buy. I am one of those that likes the cutting edge, but with overclocking patience is required and you should let other people's bad experiences pave the way for you
Also, more importantly, I haven't been able to afford a new system for a few years
Anyways, now that the Socket 939 platform is mature and we are starting to see the "future legendary overclockers" stuff come out, it seemed like the right time to jump in.
After looking around and watching other people's threads closely, I decided on the Asus A8R-MVP / Opteron 170 combo.
I ended up getting a Corsair XMS 2gb kit for the ram and a Fortron Source FX600-GLN for the power supply. A good friend is donating a Radeon X800XL for me :hitit2:
Not sure yet if I can get that card to work in crossfire mode.
I'll update this thread as my experience continues. For now I have all the parts except the video card.
Should be a killer rig prime..
IIRC, the X800XL pci-e cards are crossfire capable. Just have to get a master card to go along with it. Of course, it usually makes a lot more sense to sell your card and get a single current-gen card
You'll enjoy your FX60 immensely.. err.. Opty 170 @ 2.6+GHz
I plan on using the ultimate 754/939 overclocking guide to pull off some crazy speeds
I'm not sure if they ever did get around to releasing other x8xx master cards. I know the x850XT master card is readily avaliable and should work. It will simply reduce it's clock speed to match the x800XL.
What stepping 170 did you get?
Good choice. That's the king of air-cooling at the moment :thumbup
CCBWE 0546XPMW
That is a strong stepping. 2.6GHz should not be a problem (may just need a minor vcore boost)
One Sapphire X850 Crossfire edition + one Gigabyte X800XL card should get me over 11K in 3DMark05, right?
This should be a very significant leap over my current 2600+ Athlon XP / Radeon 9800Pro setup
Prime, I did some checking up on your motherboard. It appears that it has really mixed user reviews on its stability and OC performance. The good news is that many of the problems people are experiencing appear to be related to lack of user experience in computer tweaking. Good news, in that there may be little gremlins with the board, but problems that you will be able to work through. The good news is that many users are reporting excellent stability and overclocking with the board. Recommend that you do some searches on user experiences. But I'm sure you already have.
The big typhoon is very quiet though
Do you guys think the passive sinks + arctic silver 5 is enough or should I get some active cooling on the sinks?
When overclocking, if you are still concerned about the northbridge temperature, just reach in and feel it. If it feels hot, time for action; if it feels just warm, you are in good shape. There are always ways to rig fans. If low amperage, splice on a three pin connector. If high amperage, connect to a four pin molex.
Brian, how experienced are you with mounting CPU heatsinks that require through board mounting with a backplate? Although the Big Typhoon has lots of mounting hardware, it's fairly straight forward. Go online though, and study the installation guide before you start to install it. If you aren't careful, the heatsink won't be flush with the CPU's heatspreader. If you are careful, you can lift your motherboard with the sink and move it around. The mounting system is that stable.
I've been looking up that stepping and you shouldn't have any problem with 2600. The thing that will probably hold you back for now will be the vcore limit at +-1.5. You will be amazed at how cool this chip runs.
edit:\ Also, here's the latest review of the mobo. It should have been published a lot sooner but as I've learned from reading it they had issues with the crossfire. Seems everything turned out fine though.
Check it out ...http://www.hardocp.com/article.html?art=OTU1
"I would suggest that some extra northbridge cooling be introduced if you plan on overclocking this motherboard as it gets to be extremely hot. We used a 120mm fan directed at our northbridge heatsink as well as the power components heatsink on the motherboard. A small amount of airflow managed to keep these very cool."
what size monitor will you be using? are you getting the x800xl for free? have you bought the x850xt master card already?
i would sell the x800xl and use it towards the purchase of a x1900xt. it will waste the neutered crossfire setup easily.
So you think I should cancel the x850xt order, and sell the x800xl towards an x1900xt?
Comb some 3dmark06 benchmarks and see what these guys are getting with these cards brian. Not too impressive even with crossfire.
IMO you could run the free card for now until you've checked out vid cards a little more before you decide.
The x1900xt is teh kickbootie card today! All of the high end cards are too pricey for me.
edit:\ if I were going ati video right now the only card I would consider is the x1900xt but considering the price ...etc. Look around at the 7800gt and up as well. Don't rule them out if you don't want to spend that kind of cash on this system. Pee'er pressure sucks sometimes don't it??? :headbange
well since you are getting them both at a severe discount (i.e. free!) it is a little different.
but yes the x1900xt will smoke the x800xt(xl) crossfire setup.
i asked about the monitor b/c if you have a 1600x1200+ lcd/crt then you would pretty much have to go with a x1900xt. the 1st gen of crossfire stuff doesn't support super high-res gaming.
I can't cancel the x850xt order, as it already shipped. For once I wanted newegg to be slow, and they weren't. I didn't pay for rush shipping and they still sent the thing out almost immediately
So I'm going to consider this a unique challenge. I'll have a weird setup with mismatched cards and I have to make the best of it
The price was definitely right!
just x800xl
just x850xt
x850xt(xl) crossfire...
i am very interested in the results. I would think that the crossfire setup is really only going to benefit you when you max the AA/AF. fun, fun!
SILVERSTONE SST-ST60F ATX 600W Power Supply
It's a little pricey but it's top notch. I have the "Zeus" version and it's solid. It even has the 8pin connector for your MSI K8N Diamond Plus mobo
